Arena 3U 32TB Fibre Host RAID System
Quicklinx:
6C5FWS00
Mfr#:
SS-6551E/32TB
£8,505.30
inc VAT
Marketing description is not available.
- Arena JanusRAID2 SS-6551E - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 3U
- Total Array Capacity
- 32 TB
- Interface
- 4Gb Fibre Channel
- Host Channels
- 2
- Installed Devices / Modules Qty
- 16 (installed) / 16 (max)
- Supported Drives
- Serial ATA-300
- 48.5 cm x 56.5 cm x 13.2 cm
- 24 kg
- Built-in Devices
- Status LCD
- Storage Controller
- RAID ( Serial ATA-300 ) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 60
- Hard Drive
- 16 x 2 TB hot-swap
- Power
- AC 120/230 V ( 50/60 Hz )
- Power Redundancy
- Built-in
- 3 years warranty
- Hard drive array
- Enclosure Type
- 48.5 cm
- 56.5 cm
- 13.2 cm
- 24 kg
Cabinet (Chassis)
- Built-in Devices
- Status LCD
- 16
- Supported Devices / Modules Qty
- 16
- Supported Drives
- Serial ATA-300
Storage
- 32 TB
- HDD Array External Interface
- 4Gb Fibre Channel
- Host Channels
- 2
- PowerPC 405SP
Storage Controller
- RAID - integrated ( 4Gb Fibre Channel )
- Data Transfer Rate
- 400 MBps
- Controller Interface Type
- Serial ATA-300
- Cache / Buffer Size ( Max )
- 1 GB (installed) / 4 GB (max)
- Supported Devices
- Hard drive, disk array (RAID)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 60
Storage Hard Drive
- Hot-swap - plug-in module
- Capacity
- 16 x 2 TB
- Expansion Bays Total (Free)
- 16 ( 0 ) x hot-swap - 3.5"
- 2 x 4Gb Fibre Channel - SFP (mini-GBIC) , 1 x serial RS-232 ( management ) - 9 pin D-Sub (DB-9)
- Mounting Kit
- Included
- CE, UL, C-Tick, BSMI, cUL, CB, FCC
- Power Device
- 2 x power supply - hot-plug / redundant - plug-in module
- Max Supported Qty
- 2
- Power Redundancy
- Built-in
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 460 Watt
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80%
