Click to visit BT.com
Arena 2U 24TB iSCSI Host RAID System
Quicklinx: 6C5LWS00
Mfr#: SS-4503S/24TB
£6,708.60 inc VAT
The JanusRAID II SS-4503S is a single controller, iSCSI to SAS RAID Subsystem. In a compact 2U - 12 bay chassis, featuring hot-swappable power supplies and fans. The RAID controller, fans, and power supplies are modularized allowing for easy removal from the rear of the unit. System setup is simple using web browser allowing easy remote configuration and monitoring. Copy-on-write snapshot functionality is built into the controller to help protect your data.
iSCSI protocol uses TCP/IP to transfer data, which only requires an Ethernet interface, and enables easy integration into your current network infrastructure. iSCSI encapsulates SCSI commands and data into TCP/IP packets to transfer through a Ethernet network. By using TCP/IP to transfer ensures that the transmission is successful, and provides a reliable means of transfering data. Also, by using your current network infrastructure reduces the total cost of ownership.
Arena JanusRAID2 SS-4503S - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
24 TB
iSCSI
Host Channels
4
12 (installed) / 12 (max)
Supported Drives
Serial Attached SCSI
48.5 cm x 56.5 cm x 8.8 cm
19 kg
Built-in Devices
Status LCD
Storage Controller
RAID ( Serial Attached SCSI ) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Hard Drive
12 x 2 TB hot-swap
AC 120/230 V ( 50/60 Hz )
Power Redundancy
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
48.5 cm
56.5 cm
8.8 cm
19 kg
Chassis
Built-in Devices
Status LCD
12
Supported Devices / Modules Qty
12
Supported Drives
Storage
24 TB
HDD Array External Interface
iSCSI
Host Channels
4
IOP342
Storage Controller
RAID - integrated ( iSCSI )
Controller Interface Type
Cache / Buffer Size ( Max )
1 GB (installed) / 2 GB (max)
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
Hot-swap - plug-in module
12 x 2 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap - 3.5"
4 x Ethernet , 1 x serial RS-232 ( management )
Mounting Kit
Included
CE, UL, C-Tick, BSMI, cUL, CB, FCC
2 x power supply - hot-plug / redundant - plug-in module
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
350 Watt
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
20 - 80%
feature value
Type Hard drive array
Controller Type RAID
Brand Arena
Price Range Inc VAT 1500+
