Click to visit BT.com
BT.com
Wishlist
Acer V193HQV 18.5" Widescreen 1366 x 768 5MS VGA LCD Monitor
Quicklinx: 7DS7WS00
Mfr#: ET.XV3HE.024
Essential accessories
The best buy for those who require budget-friendly performance, Acer V series monitors offer a powerful display solution with an affordable price tag. Designed for word processing and graphics rendering, Acer V series monitors conform to the highest safety and reliability standards for the most comfortable and productive viewing. V series LCD monitors come in a black bezel that enhances any viewing environment, and an elegant, sturdy black base with a deep-cut Acer logo that represents quality without compromise. Control buttons on the front panel allow easy cleaning and intuitive use, imbuing this budget-friendly monitor series with ergonomic as well as aesthetic appeal.
All monitors undergo rigorous durability testing and adhere to high safety standards to ensure that each display is reliable and provides a comfortable viewing experience. A wide viewing angle maintains color consistency and image clarity, allowing you to share content with others without having to crowd in front of the screen, for an excellent viewing experience. Acer leverages three primary technologies to improve contrast ratio performance for viewing an LCD monitor from different angles to present you with a big, lifelike picture. V series monitors feature screwless assembly/disassembly for quick and easy attaching/removing of the base, making it easy to pack and take the monitor anywhere!
Acer V193HQVb - LCD monitor - 18.5"
LCD monitor - 18.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m2
Contrast Ratio
5000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
44.4 cm x 17.7 cm x 33.5 cm
3.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TCO '03, TUV GS, ISO 9241-307
3 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
18.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m2
Contrast Ratio
5000:1 (dynamic)
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
176
Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
3.5 kg
VGA
Mechanical
Tilt
Tilt Angle
20
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable
Power Supply
Internal
20.1 Watt
3 years warranty
Service & Support Details
Limited warranty - 3 years - carry-in
