Click to visit BT.com
Garmin Nuvi 265W
Garmin Nuvi 265W Image for illustration only
Garmin Garmin Nuvi 265W
Delivery 3-5 days
Quicklinx: 5BQYWS
Mfr#: 010-00575-11
£148.52 inc vat
Simple, safe and affordable with Bluetooth® hands-free phone calling, the nüvi 265W is your personal travel assistant for life on the go. This simple, safety-minded continental navigator leads the way with turn-by-turn directions and a unique, advanced safety camera warning system to help you find the best route and stay safe on the road. Give the drive your full attention with hands-free phone calls through the integrated speaker and microphone. Packed with up to millions of points of interest (POIs) and maps for Europe, the 265W is compact, versatile and easy to use.
Make hands-free phone calls -Keep your eyes on the road and both hands on the wheel with nüvi 265W's integrated Bluetooth® wireless technology, microphone and speaker. Just pair with your compatible mobile phone and talk hands-free through the nüvi 265W. Simply dial numbers using nüvi's touchscreen keypad and answer calls in a tap of the screen. Enjoy convenient one-touch dialling for contacts and points of interest and drive safely and legally.
Simplicity and safety - nüvi 265W comes preloaded with street maps for Europe. Simply touch the colour screen, key in your destination and nüvi takes you there with turn-by-turn spoken directions, announcing the road and place names as you approach for greater on confidence on unfamiliar or busy streets. The 265W has smooth moving maps and digital elevation detail, showing shaded contours for a better understanding of your surrounding terrain. In addition, nüvi 265W accepts custom points of interest such as named businesses and traffic blackspots, with proximity alerts to warn you of upcoming POIs as you approach. With HotFix™ satellite prediction technology, Garmin calculates your position faster to get you there quicker.
'Where Am I?' gives you details about your position on command. Simply tap the car icon for your exact latitude and longitude coordinates, nearest address, contact details for your appropriate vehicle recovery service and directions to nearby hospitals, police and petrol stations.
nüvi 265W contains Garmin's unique, advanced driver safety system with daily updates. Travel with the confidence you are driving safely, responsibly and legally and don't be fooled by false alerts. The system uses a patented `corridor' technique of camera validation so you only get alerts relevant to cameras on your route. nüvi also displays speed limits for greater awareness.
nüvi 265W also comes with Garmin Lock™, our inventive anti-theft protection system that uses GPS technology to safeguard the sat-nav by locking to a secure location of your choice. Just return to the location to unlock.
Other built-in travel tools include a JPEG picture viewer, world travel clock with time zones, a currency and measurement converter, calculator and more.
Customise - Personalise your nuvi 265W with your choice of background photograph and select a new vehicle icon from the Garmin Garage. With a wide range of wheels including off-road vehicles, motorbikes and classic cars, you can tailor your Garmin to suit your style.
Portable bigger picture - nüvi 265W has a sleek, slim design to fit comfortably in your pocket or bag. Its rechargeable lithium-ion battery makes it convenient for navigation by car or foot with up to 4 hours' usage between charges.
View map detail, driving directions, photos and more in bright, brilliant colour. The sunlight-readable 4.3-inch display is easy to view - from any direction.
nüvi 265W: Simple, safe and affordable continental navigation with Bluetooth® hands-free phone calling.
Garmin nüvi 265W - GPS receiver
GPS receiver
Recommended Use
Automotive
12.2 cm x 2 cm x 7.4 cm
173 g
Maps Included
Europe
Included GPS Software
MapSource City Navigator NT
Compatible GPS Software
MapSource MetroGuide, MapSource City Navigator, Garmin Travel Guide, Garmin Language Guide
USB
GPS Functions / Services
Distance, time/date
Speed Camera Warning
Built-in
Voice
Navigation instructions, street name announcement
Waypoints
1000
Routes
0
Built-in Display
TFT - widescreen - 480 x 272 - colour
Digital Player
JPEG
Supported Memory Cards
SD Memory Card
GPS receiver
12.2 cm
2 cm
7.4 cm
173 g
GPS System
Recommended Use
Automotive
USB
Distance, time/date
Built-in
Voice
Aerial
Built-in
Hands-free calling via Bluetooth, built-in microphone, built-in speaker, calculator, clock, JPEG photo playback, Speed Camera warnings, speed limit warning, 2D / 3D map perspective, TMC (Traffic Message Channel) ready, Garmin Lock, photo viewer, custom POIs, preinstalled POIs, automatic routing, measurement converter, currency converter, Garmin Garage, Garmin HotFix, Emergency Help
SD Memory Card
Maps Included
Europe
Software Included
Navigation
Waypoints
1000
Routes
0
Trip Computer
Avoid highways, trip timer, trip distance, quickest route, avoid toll roads, fast/short route, street address search
Built-in Display
TFT - widescreen
Resolution
480 x 272
Diagonal Size
4.3"
Display Illumination
Colour Support
Touch screen, anti-glare
Digital Player
Supported Formats
JPEG
Connector Type
USB
Battery Enclosure Type
Internal
Included Qty
1
Lithium Ion
Run Time (Up To)
4 hour(s)
USB cable, dashboard disc, suction cup mount
Accessories
1 - 3 products displayed out of 3
  product description   In stock inc vat qty
  Garmin nuvi 2xx suction cup mount & 12v power cable kit Garmin nuvi 2xx suction cup mount & 12v power cable kit
quicklinx: 622SWS | Mfr#: 010-10979-00
None in stock £21.69
  Garmin Suction cup mount Garmin Suction cup mount
quicklinx: 622RWS | Mfr#: 010-10936-00
Delivery 3-5 days £16.10
  Garmin A/C Charger for GPS Garmin A/C Charger for GPS
quicklinx: 5LFHWS | Mfr#: 010-10723-00
None in stock £16.74
feature value
Display Size 4.3"
Recommended Use Automotive
Region UK, Ireland & Europe
Brand Garmin
Price Range Inc VAT 100 - 150
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
Free Delivery on BT branded products - click for details
Recently Viewed
