Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
3M MPRO 150 VGA Micro Projector - 15 ANSI Lumens
Quicklinx: 70PLWS00
Mfr#: MPRO150
The 3M MPro150 is a hand-held, battery-operated projector from 3M. Now you can project cord-free with internal storage that enables you to download and organize your files. Project images and videos on almost any wall, almost anywhere.
3M MPro150 LCOS projector
LCOS projector
Built-in Devices
Stereo speakers
Brightness
15 lumens
Resolution
VGA (640 x 480)
Native Aspect Ratio
4:3
Bulb type
LED
Bulb life cycle
20000 hour(s)
Video Input
RGB, composite video, component video ( NTSC, PAL )
Supported Memory Cards
SD Memory Card
Video Modes
480p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
6.1 cm x 13 cm x 2.3 cm
159 g
1 year warranty
LCOS projector
Built-in Devices
Stereo speakers
Projector
Brightness
15 lumens
Image Size
20 cm - 127 cm
Resolution
VGA - VGA (640 x 480) (native) / 1280 x 768 (resized)
Native Aspect Ratio
4:3
Bulb type
LED
Bulb life cycle
20000 hour(s)
Controls & Adjustments
Volume, brightness, focus
Built-in 1 GB flash memory
Lens
Focus Type
Manual
Video Input
TV System
NTSC, PAL
Analogue video Signal
Video Interfaces
VGA, component video, composite video
Video Modes
SD Memory Card
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
0.5 Watt
Speaker(s)
2 x right / left channel
Expansion Slot(s)
1 x SD Memory Card
1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x component video input - RCA x 3 , 1 x USB 2.0 , 1 x audio line-out - mini-phone stereo 3.5 mm
Carrying case, tripod, 2 GB microSD Memory Card
External
Run Time (Up To)
2 hour(s)
6.1 cm
13 cm
2.3 cm
159 g
1 year warranty
Service & Support Details
Limited warranty - parts and labour - 1 year
